Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Freelander
Register Forgot Password?
Old 01-13-2011, 02:23 AM
Junior Member
Default steel water pipes.
hi.
my 1999 2.0l rover diesel freelander has just lost all its coolant!! (what a suprise!!). I have found two small holes in the steel water pipes that run over the gearbox. Does anyone know if you can buy these as a pattern part, or is it down to the main stealer for a ridiculous quote!!
i also thought of repalcing them with copper... has anyone done this before and succeeded (or failed)?
thanks
chris
Old 01-14-2011, 01:02 AM
Junior Member
i went ahead and made them out of copper. all seems to be working fine so far. ill keep you posted of any problems but at least i wont be suffering from rusty pipes again!!
also to make it easier to make and fit the new pipes i removed the inlet and exhaust manifold( with turbo attached). this made bending and checking the pipes much easier!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
