Transmission Won't Go Into Gear, Won't Move at All
I'm sure there are better ways, and I don't know how you have the truck supported, but personally, I get the inner and outer splines engaged, and use the knuckle as some sort of a slide hammer, and holding the rotor, slam it in a few times. I wouldn't recommend a hammer on the axle, as damage to both the threads, and the CVs can occur. But it will go, just be patient, and once the patience runs out, it usually goes in the next time.
Got the new axle in and although the car now engages and starts to move forward and backwards it is binding massively! Sounds like there are rocks in the IRD, not good! I'm assuming something let loose or gears have broken as I can't even drive a few feet without it binding up and surging, popping and just making a ton of bad noises.
Sounds like the next step is to pull the IRD and inspect it? It absolutely blows my mind that these things have so many drive train issues, especially at 60K miles! Seems crazy!
No, the CV is fully engaged, didn't really fight it much. It really sounds like a "crunching" noise coming from the IRD area. Guess I could try lifting the front end and putting it into neutral and see if I can spin the front tires?
Station1
06-01-2018 01:17 PM
capthook
09-22-2014 11:05 AM
deleon_daniel@sbcglobal.net
11-29-2010 09:56 AM
felipenaves
11-05-2007 06:49 AM
