Sponsored by: DashLynx
1999 p38 milky water leaking on front passngr floor
Old 02-20-2011, 04:33 AM
southarm34's Avatar
Default 1999 p38 milky water leaking on front passngr floor
Ahoy fellow rangey rats. i and my mechnic are stymied by masses of water which drips from under the dash on passngr side of car (in australia that is the left side), a 1999 P38 Rangey. Thought at first it may be condensation from AC cooling (it still may be) but still happening apres clean out of AC drain. Please don't suggest floor waste - tho that may make more sense than rebuilding vehicle.
Also is there a straight forward way of changing the tailgate wiper blade without sending the car back to the factory.
Old 02-20-2011, 09:12 AM
Are you 100% sure it is water leaking and not engine coolant?
Are there tons of debris trapped in the fresh air intake for the passenger cabin preventing rain and carwash water from draining?
Did you ream out the a/c drains with something like pipe cleaner and get as far up as you can? Or did you just squeeze the nipples until the water stopped?
Maybe a clog at the top of the a/c drains?
spiritchaser
LR2
09-25-2014 09:48 AM
LRgirlfromMS
03-06-2013 03:51 PM
Shawn Cross
06-11-2012 08:22 AM
bentjeep67
06-16-2011 05:43 AM
Babysdisco
03-30-2011 09:11 PM
Quick Reply: 1999 p38 milky water leaking on front passngr floor
