2003 Disco Rt Rear Window Won't Roll Down
check the fuse, and swap the switch to rule out anything else first. if it still doesnt work than you need a regulator. download the RAVE manual its the workshop manual for your truck. its free at http://www.landroverresource.com/
Also, the electrical manual on RAVE will give you the wiring to the switch so you can check to see if you're getting voltage.
On my 95 when a rear window failed on a trip (failed in the down position with a storm coming) I was able to jumper the pins with power and get the window up.
