If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
2003 im pretty sure they didnt have wires.... its coil on plug try swapping coils around. check spark plugs and make sure the valve cover gaskets arent leaking oil into the coil/plug area that will foul them pretty bad you can tell by pulling a coil or plug out if its covered in oil. your going to need new valve cover gasket sets
