Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 12-19-2011, 07:27 PM
Junior Member
Default 2007 HSE Sport Heat problem
I have no heat from drivers side vents. Checked blend door and it is operating fine. Manually opened and closed blend door and no change. Wondering if there are any other common issues it could be before I start digging into the dash.
Old 12-19-2011, 08:13 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Rovin4life should have a idea, he is a LR tech.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 12-19-2011, 09:54 PM
Senior Member
We had issues with programming causing the problem but if you manually operated the drivers blend door under the dash on the hVAC assembly then its possible the door is jammed open with some sort of debris in it. Recently replaced a manual vehicle that had twelve pens in the box.
a colleague with an xtype found a swiss army knife in one.
The air actually is warmed by the heater core, it passes thru the evaporator first and then the blend door moves the air to the appropriate side and it gets warmed by the heater core on the way out.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 12-20-2011, 04:54 AM
Junior Member
I'm going to check into possible blockage today. When I operate the door manually there doesn't seem to be anything inside the box. I get a pretty solid "thump" when it closes. I tried back flushing the heater core thinking it may have a partial blockage, but it seems ok.
Tags
2007, blend, door, drivers, heat, heater, hse, issue, land, motor, range, rover, side, sport, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
