Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 02-13-2012, 03:47 PM
Junior Member
Default 99 disco2 stalls
My LR has 135000 miles on it. It stalls after about 15 minutes of driving. Usually when the outside air temp is below 50 dedrees and sitting at a light. It only does it once or twice then it is ok. It will occasionally hesitate while driving at a steady speed. It restarts immediately. Service engine light came on. I replaced the MAFSand it ran good for several months and started it again. I replaced the crank shaft position sensor to be on the safe side but that did not correct the problem. Any other causes???????
Old 02-13-2012, 06:14 PM
Senior Member
Codes? Fuel pressure test?
__________________
Old 02-14-2012, 08:00 AM
Junior Member
Thanks. Is there a port that I can use to test FP?
Old 02-14-2012, 08:57 AM
Send a message via Skype™ to Disco Mike
How about codes? When was it last tuned along with 8 mm silicone plug wires?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 02-14-2012, 10:27 AM
Senior Member
If a D1 the schraeder valve (tire valve) is on the battery side fuel rail. On a D2 it under the top section of the intake at the firewall/driver's side corner (NAS).
__________________
Tags
land, rover, sitting, stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
