If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
cheapest route is drive on it till its empty and then add pure premium to get it running right. the next expensive route is to take out the gas pump and drain the fuel completely and again add pure premium for a few tank fulls. then clear the codes and hope and prey it didn't damage the fuel pump.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Freelanders call for 87 octane if I'm not mistaken. Ethanol is an octane booster, so why add 93? I would worry about a lean condition running the E85, so I would mix as much ethanol free fuel as you can.
Check your owners manual, Freelanders have a BMW engine, I am pretty sure it requires premium fuel, just like every other Land Rover.
The "opps I put in E-85" wont hurt anything once, but do it over and over and the fuel pump will die a quick death.
E-85 is a great injector cleaner.
87 octane minimum. Not trying to be argumentitive, but I'm in the marine industry and have to deal with ethanol issues constantly. When I tell customers about problems they are having because of ethanol, the 1st thing out of their mouth is "I only use premium", and it's like pulling teeth getting them to understand it's not an octane issue, and what ethanol is and does(positive and negative)
whats really fun is when the gas companies mix too much ethanol and regular premium has 12 percent or more and causes the check engine light to come on.
__________________
