Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 12-07-2011, 06:57 PM
Senior Member
Default Basic TPS test with scanner
Was able to see TPS changes smoothly on scanner. With scanner plugged in, turn key to position 2, don't crank. OBDII scanner will boot up, and display values, including the TPS percentage. My bottom reading was 9.4%, which may vary from truck to truck. Pressed gas pedal slowly, and % changed slowly, always up, and never by very large jumps. Floored was 90%, again that may vary by truck. Release quickly and it is right back to original low percentage. Move pedal, and percents changed smoothly and without unexpected jumps.
This might be a quick check when a TPS is suspect, and volt meter not on hand.
__________________
Old 12-07-2011, 08:25 PM
Philip Lawrence
Send a message via Skype™ to Spike555
The throttle on a DI is set up for offroading, very small inputs on the throttle move it very little to allow you to "finesse" the truck into places you probably shouldn't be going.
That is why you saw small increases on the TPS, the bottom half of the throttle is "geared" low and the top half is "geared" higher for quicker throttle response at higher speeds.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 12-08-2011, 06:54 AM
Senior Member
That's what i thought. If the "pot" was real dirty or noisy, the readings would jump all over the place.
__________________
Old 12-08-2011, 07:12 PM
Philip Lawrence
The LR3 and LR4 both have a "fly by wire" throttle and when you put the t-case into lo range it changes the TPS values for offroading so that small inputs can be done.
Kinda cool but I still am not a fan of fly by wire throttles.
__________________
www.marshill.org
www.20liters.org
Tags
97, check, classic, land, obd2, plug, position, range, rover, scanner, switch, test, testing, throttle, tps, values
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
