Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 01-06-2012, 07:23 PM
Junior Member
Default Battery draining overnight
I bought a new 3 year battery about 3 months ago from autozone and recently it died completely. The keyless entry didnt even work. So I jumped it off and drove it to autozone so they could test it and said it had a 45% charge so I let it run a little longer to get more charge on the battery so that they could test the alternator, which turned out to be fine. So I drove it home and this this morning I tried to crank it up and it was dead yet again. I have made sure no interior lights or anything were left on. I have no idea what the problem is. Please help!!
Old 01-06-2012, 08:46 PM
Senior Member
We will assume that what the store told you is true, that battery indeed was "discharged", and that it "charged up", and that your alternator is putting out full power. Since you did not mention your model and year, can't tell you the amps.
But when turned off the truck battery should read 13.2 volts or above. When cranked, it will increase to 13.8 - 14.2 volts.
Now when you turn it off, there are things that keep running, like alarm system, clock, radio memory, etc. But usually it is a larger drain that kills the battery. It sounds like you don't have a voltmeter handy, so here is a shade tree method. With tuck not running, remove + battery terminal. Take a tail light bulb and hold it where metal sleeve of the base touches the (+) post. Touch the battery terminal to a base contact on the bulb. If you have a substantial drain the bulb will light. You can then pull fuses to isolate this.
__________________
Old 01-06-2012, 08:59 PM
Junior Member
thank you very much I'll give that a try.
oh, and mine is a 2002 D2.
thanks again !
Old 01-07-2012, 07:45 AM
Send a message via Skype™ to Disco Mike
What is the cold cranking , CCA, rating on your battery? Did you have some one recharge the battery after it died, driving it a little won't give you much if any of a charge unless driven for 2 to 3 straight hours.
Get it started and go back to where you bought that battery, have them do a charging test. The system needs to be between 13.6 and 14.4 volts or you have a problem.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-07-2012, 11:31 AM
Senior Member
basically you have to do a draw test to find out what is causing the problem. you need a multimeter that reads Amps and then you have to test the system. it should only be 30 milliamp draw.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
battery, drain, drains, draw, fange, land, landrover, lr, overnight, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
