Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 12-15-2011, 02:32 PM
leadfoot's Avatar
Senior Member
Default Clean Cats
I have read a couple of threads about removing the Y pipe and washing the CATs, is that a good practice? Does it make sense?
Also does someone know the real difference, if any, between the Oxygen sensors on the Standard Evap system and the Advance Evap System other than the connectors? I know they change in 1997 from one to another, but I believe the only difference is the connector and a bunch of money.
__________________
Land Rover Discovery 1997 152K
Mitsubishi Montero 1998 140K
Toyota FJ Cruiser 2007 50K
BMW Z3
Old 12-15-2011, 07:48 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Buy the O2's on Amazon, they have the best prices.
I do not know if there is a difference in the O2's other than the connectors.
As for washing the cats? Cats hate water, they will cry and scratch and do whatever they can to get away, dont do it.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 12-15-2011, 08:53 PM
Senior Member
A man that can wash his weight in house cats is truly a man...oops - wong cats..
Heres a video on two shade tree ways to do it, one with a plain solvent, no removal required.
__________________
Old 12-15-2011, 09:00 PM
Philip Lawrence
I dare someone to dump a gallon of lacquer thinner into their gas tank.
__________________
www.marshill.org
www.20liters.org
Old 12-15-2011, 09:14 PM
Senior Member
Well, how about some CRC? CRC Industries | Automotive, Heavy Duty, Marine & Hardware They make a good MAF cleaner... but people will put anything in their tank it seems. Acetone, laquer thinner, sheep oil, etc. Won't make up for 50,000 miles of slow driving on regular gas...
Old 12-16-2011, 06:57 PM
Philip Lawrence
I talked to a industrial chemist a few years ago when the whole acetone in the gas tank kick was going big.
He said it does nothing to increase MPG like people claimed, he said that you cannot change the molecular make up of gasoline without actually changing the production process.
And all that those people were doing was ruining their injectors because that much harsh cleaner was not good for them.
__________________
www.marshill.org
www.20liters.org
Old 12-16-2011, 11:13 PM
lordmorpheus's Avatar
Senior Member
Since I just posted on another thread about this...
BG Findashop - Search for an authorized BG service center near you!
The shop I used to work at was a BG shop. When a vehicle came in with a P0420 catalyst efficiency below threshold code, the BG induction service was the first thing recommended. A few vehicles needed the service twice before the code was not gone. These were vehicles that other shops would have replaced the converter. After the proper cleaning(s), we NEVER had a comeback.
These were all vehicles with a "failed" converter. Granted, we did replace a few converters, but the majority were cleaned with the induction service.
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Tags
catalytic, cleaner, converter, crc, lacquer, thinner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
