code p0012 and misfire code p0307. - Land Rover Forums - Land Rover Enthusiast Forum
Old 10-26-2010, 01:17 PM
Junior Member
Default code p0012 and misfire code p0307.
the sound is comming from the passanger side valve cover. I read the codes and it is giving the p0012 and p0307. I have replaced the lower timing chain tensioner and I still have a loud ticking noise. The noise gets louder on acceleration and the p0012 and p0307 code came back on.
Could this be caused by the Cam sensor being bad. 2003 Range rover
Thanks for any help or insight in advance
Regards,
Todd
Old 11-03-2010, 08:58 PM
Senior Member
the bmw engines have very little problems. But if you want more info ask the bmw guys. its a 4.4 liter M62 engine. we use the same parts as well.
Old 03-27-2013, 06:16 PM
Junior Member
I have the same P0012 code. Any suggestions? I read that the cause might be the VARIABLE CAMSHFT TIMING solenoid (VCT)
Thread Thread Starter Forum Replies Last Post
She's stuttering and rumbling around, throwing P0304 and P0307, plus coolant loss. flanker6 Discovery II 3 01-08-2015 10:35 PM
2003 disco II has p1300 p0303 p0305 p0307 p0135 p0300 p0307 p0130 p0303 rtindle1975 Discovery II 42 06-11-2014 04:05 PM
Single Misfire P0307 please help(!) Murph2121 Range Rover 4 02-20-2013 02:00 PM
SES light , Code P0307 Please help! jimbo972 Discovery II 3 07-14-2010 10:00 PM
Discover II 2000 - P0307 Cylinder 7 Misfire Detected mtat Discovery II 7 10-02-2008 11:03 PM
Tags
03, 44, bad, bmw, cam, code, codes, engine, hse, land, landrover, misfire, p0012, p0307, poo12, range, reads, rover, sensor, simptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
