Disco 1 ignition switch HELP!!!
Hi i recently purchased my first land rover and am having to fix a couple of things.
I purchased a new ignition switch for a manual transmission mine is an automatic i installed the new switch and now the truck will not start i have no start up procedure at all. Im a noob so please help i have already purchaced 2 different switches with no luck what so ever. The disco ran when i purchased it i broke the key off in the ignition thats why im replacing it. 1997 disco 1
I am preparing to replace my ignition switch too. I have a 99 Disco I SD with automatic transmission. I'm guessing the switch for the manual transmission won't work as it likely looks for a signal from the clutch before it will start and your wiring harness doesn't match up to the switch. Can you provide more details? Does the key turn as you would expect? Does the engine turn over?
The switch for a manual will work in an automatic, but you won't have the park/neutral safety switch functional or the transfer case interlock functional (manuals don't have them).
Best thing is to get the RAVE and compare the circuits between the manual ignition switch and automatic ignition switch.
Hi
I'm not sure but someone may be able to help - are the keys coded to the ignition/steering lock and BCU? if they are you may need the key and locks re-coded. Just a thought.
http://robisonservice.blogspot.fr/20...and-rover.html
http://www.key4less.biz/car-keys-land-rover.html
So my ignition switch/steering lock wore out and the key wouldn't turn anymore. I removed the steering lock from the steering column and unplugged the wiring. I then removed the ignition switch in an attempt to "get by" until a replacement arrived. I was hoping to simply use the ignition switch to start my 99 Disco ! SD. When I turn the switch to "Start" the engine turns over (sounds normal), starts for a second or two and then immediately dies. After several tries, it stays running and appears to run just fine. Odd thing is that it started/ran just fine before pulling the ignition switch. My question is this - is the start/die problem related to the fact that my steering lock and various interlocks have been removed (I'm essentially hot wiring my Disco) or is it likely something else? I replaced the Crank Position Sensor not too long ago; however, its acting like the sensor is on its last leg. I appreciate any suggestions!
