discovey fuel pump question
Old 07-07-2010, 04:16 PM
christians1600's Avatar
Default discovey fuel pump question
1996 discovery ..just replaced the fuel pump a month ago (aftermarket) and now everyonce in a while with a 1/4 tank of gas the disco stalls and wont start until after 5 minutes and then it runs fine, no wierd idle or anything ..is this the throttle control sensor
or did i do something wrong with the fuel pump?? thanks..........
Old 07-08-2010, 05:15 AM
Rovin4life's Avatar
change the filter. if that doesn't cure the intermittent stall then try to recreate it and diagnose it from there. It could be anything. improper set up on the fuel pump. kinked line inside the pump.
Old 07-08-2010, 07:50 AM
Default filter
thanks i had already changed the filter and hoses r new and not kinked..so if the car stalls and wont start again for 5 minutes and then runs fine would this be the throttle sensor?? thanks..also its about 95 degrees here.......
Old 07-09-2010, 05:53 AM
Rovin4life's Avatar
I cant tell until I put a fuel pressure guage on it and the like. Their are other reasons like a bad multifunction unit near the ECU or it could be the ECU itself is fried. Lots of reasons. Need to diagnose.
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
mydisco03
01-11-2010 02:21 PM
dieselgeek
01-19-2009 07:41 AM
Quick Reply: discovey fuel pump question
