If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Hello,
Could anyone tell me if the buttons on the Climate Control below the LCD (Disco 2) are supposed to be illuminated when lights are on. Seems like they sould but mine do not. If a bulb or led must be replaced, any tips on replacing it?
__________________
1999 D1 sold with 175k miles
2004 D2 - 81K miles and counting
900ss Ducati
Triumph 955i Sprint ST
Suzuki 1200 Bandit
Rinker Festiva 230
Garden tractor and Weed Whacker
2005 GTO in the house
There is a bulb listed on the wiring diagram for the automatic temp unit. Here are some RAVE pages for it. Would appear to get module out you might have to pull out radio first, there might be a work around if you can slide some thing in on the side to ease off those spring clips.
I have the same problem, those lights burned out. The dealer told me they have a tool that slides in the space on the sides and releases the facia. I would like to see the tool so I can make one, Does anyone have a picture of that tool?
2003 Disco
74 Norton Commando 850 mint
The RAVE says take out the radio first. If there is a special tool, it is usually referenced in the RAVE with LR ###### (number of tool). Some guys have had luck with the metal strips in Pendaflex file folders.
Thanks for the tips. I have Rave. I'm not entirely sure that the illumination question has been answered. Lots of helpful tips on removing the unit. So, am I correct that the buttons should be lit at night? If there is a bulb out, does anyone know if it is even replacable?
__________________
900ss Ducati
Suzuki 1200 Bandit
Rinker Festiva 230
I replaced my HOT/COLD switch bulbs a few months back. Here's what I used to remove the radio...have your patience ready it might take a minute to get the right depth to unclip the radio. I didn't take any more pictures because I was so frustrated by the time I got the radio out.
The HVAC unit is held in by 2 spring clips on the sides. You could also remove the lower part of the dash (pull out the coin holder and ash tray and unscrew it from there) and you may be able to pull the HVAC control unit out without removing the radio. Then remove the back of the HVAC and swap your bulbs out.
__________________
Rob
----------- 2002 DII Kalahari (139K)
“We do not accept that ours will ever be a nation of haves and have-nots; we must always be a nation of haves and soon-to-haves”
