Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-22-2011, 10:59 AM
Junior Member
Default Engine makes a popping sound when going uphill
Hello everyone I am new to this site and new to my 1995 Se 4.0. The issue I am having is the followng. When I am driving and start going up hill it almost sounds like there is a hole in my manifold. The car starts to backfire or sputter. When I push the gas in more the backfire goes away but you can still here the knocking or popping sound. When I am not going uphill the car runs great. Any ideas thank you in advance.
Old 09-22-2011, 11:39 AM
Senior Member
Could be, in no particular order -
Not using premium gas
Fuel pressure (fuel pump, fuel pressure regulator)
Catalytic converter issues
TPS sensor
VAcuum leak
need new plugs and wires
__________________
Old 09-22-2011, 11:43 AM
Junior Member
Thank you Savannah Buzz. I will check those items and keep you posted.
Old 09-22-2011, 02:30 PM
Send a message via Skype™ to Disco Mike
What have you checked or done so far, when was it last tuned along with new 8mm wire, rotor/cap and points?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 09-22-2011, 05:55 PM
Banzai Jimmy's Avatar
Senior Member
Quote:
I feel like I'm missing something. Are you talking about points inside of a distributor?
__________________
'94 Disco - Lots of mods and dents, scratches and scars.
Old 09-22-2011, 08:38 PM
Philip Lawrence
Send a message via Skype™ to Spike555
The vacuum advance on your distributor is not working/hooked up.
Whenever you put a load on the engine the ignition timing needs to be advanced, with electronic ignition it is done by knock sensors and the computer.
On engines with a distributor cap and rotor it is done via a vacuum hose that runs from the distributor to the intake plenum.
If the vacuum advance hose is cracked, broken or missing the engine timing will not advance under load and you will get back firing and severe loss of power.
DI Dist. vacuum advance replacement
EDIT:the wrong grade of fuel or worn spark plugs will not cause backfire, they will just cause spark knock, that sounds like steel balls being shaken in a bag.
A back fire means fuel is being ignited before the intake valve(s) have closed and the fuel that is being ignited is going out the intake, this WILL ruin your engine in short order.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Tags
93, car, engine, grand, hill, knocking, land, makes, motor, popping, range, rover, sound, sputters, uphill
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
