If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
hi i need some help deciding what to do my disco has blown the rear seal water goes in and out at the same time. now the question is to buy a reco motor or repair this one it has 330 k's on the clock any help would be gratefull
By rear seal do you refer to water leaking down the back of the engine? Could be a head gasket. But if lucky, it could be valley pan. At your miles, engine can still be rebuilt. A manual oil PSI test will also indicate general condition of oil pump and perhaps pressure lost by worn lower end bearings. Compression test for rings.
Many write ups on this, incluidng in the truck replacement of lower end bearings, etc.
You can also get pull out motors at the junk yard, but you-pull-da-partz places usually have blown engines to start with.
Originally Posted by tornado_735I keep motivating myself saying that some poor bastard had to do the very same thing during the Camel Trophy and that I'm no different from him.
yeah i know and doing 330k's without changing them is not that bad but i will know more on the weekend when we pull it out cheers and thanku for your help
