Front Differential Ass. & RH front CV axle shaft
Old 10-07-2008, 10:02 AM
treho54's Avatar
Default Front Differential ***. & RH front CV axle shaft
Does anyone know if what is mentioned in the subject heading will fit a 2003 Discovery that comes off a 2002 Discovery?
Old 10-07-2008, 10:11 AM
Default RE: Front Differential ***. & RH front CV axle shaft
I am pretty sure it will, why do you ask? You shouldn't replace a bad one with a used one that might fail tomorrow.
Old 10-07-2008, 10:22 AM
treho54's Avatar
it will come off a 2002 and it only had about 25,000 miles on it before it was rear-ended. i just wanted to make sure they would work together, before i went out and bought them.
Thanks
Old 10-07-2008, 10:51 AM
That is good low mileage and should be fine for you. What happened to yours? Take the time and change your diff/t-case fluids while you are under there. Have you already had your front drive shaft rebuilt?
Old 10-07-2008, 10:55 AM
I just went to RoverLandParts.com, and I stand corrected, the 03 won't work on your 02.
Better look into it.
salve7
11-17-2009 05:43 PM
Street Wolf
Sights N Sounds
11-28-2008 09:22 PM
treho54
10-19-2008 04:28 PM
Sfef84
05-02-2008 05:16 PM
Quick Reply: Front Differential Ass. & RH front CV axle shaft
