If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
large black box on the passenger wheel well area.
Why are you looking for it? There are 3 relays in side it.
I was told to try replacing relay before replacing fuel pump. Truck was running fine when I parked it it was parked for about a month when I try starting its just spinning over
Start by checking the fuel pressure at the fuel rail, psi needs to be in the low to mid 30's.
Then check for spark.
If no fuel pressure replace the fuel pump relay.
