Sponsored by: DashLynx
Grenaded Timing Chain.
Old 02-20-2017, 10:42 AM
Joshua Hollahan's Avatar
Default Grenaded Timing Chain.
Help! 2002 Disco 2. Timing chain destroyed. Have all new parts. However, how do I set the engine up for correct timing? How do I verify TDC and valve train match up for the new chain and gears? I tried looking on YouTube and threads and can't find any details on timing set up.
Old 02-21-2017, 03:35 AM
The Deputy's Avatar
Received 1,160 Likes on 836 Posts
There will be a mark on the surface of each gear, crank and timing chain gear. Rotate crank until mark is on top and rotate cam until mark is down. Use a straight edge to be sure they are lined up, if you don't feel comfortable just eyeing it up.
Good luck,
Brian.
A5scott
07-11-2015 07:25 PM
Martin Rodriguez
02-25-2014 08:55 PM
91rover
12-07-2007 06:53 PM
FTB 2000 Disco
05-15-2007 07:49 AM
mrach21061
04-25-2007 11:54 AM
Quick Reply: Grenaded Timing Chain.
