Help! LR3 back top gate will not open
back latch
My Rover DiscoII does this...check the rear handle , latch....to see if it releases...comes back down...hit your lock-unlock on your key a couple times...if the latch handle doesn't come back down ...use a screw driver or? to pull the finger latch back down and try again....works for my Disco and then you need to re-lube all inside!
samwise90
04-27-2008 04:58 PM
marlymarl
07-28-2005 12:23 AM
