How to troubleshoot XYZ switch? - Land Rover Forums - Land Rover Enthusiast Forum
Old 05-16-2011, 04:59 PM
Junior Member
Default How to troubleshoot XYZ switch?
Is there any way to troubleshoot the XYZ switch (gear position switch). My 2000 LR Disco II is in the "limp" mode, M & S lights flashing. The "D" lights adjacent to the shifter are flashing and it stays in "D" and does not downshift when driving. I checked the battery and alternator. The battery is new, but I did remove the terminals and clean and retighten them. No help. I then checked the alternator which is putting out a solid 14 volts. I was told to see if the XYZ switch may be bad. I've removed it. It looks OK mechanically,,,nothing physically broken or damaged. So how can I check this thing out before I throw down big bucks for a new one that I might not need??
Matt B.
Thread Thread Starter Forum Replies Last Post
Possible XYZ Switch failure. stu44mag Discovery II 10 08-14-2010 10:28 AM
Stalls after xyz switch replaced RicknCody General Tech Help 4 03-28-2010 07:49 PM
XYZ switch replacement meltdowndave Discovery II 11 10-01-2009 07:09 PM
Tranny not upshifting after XYZ switch work. meltdowndave Discovery II 1 09-27-2009 01:08 PM
What's electically common to 3 Amigos and XYZ Switch? meltdowndave Discovery II 4 09-26-2009 11:18 AM
Tags
bad, disco, gear, ii, land, landrover, limp, mode, number, part, position, rover, switch, troubleshooting, xyz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
