Sponsored by: DashLynx
How to troubleshoot XYZ switch?
Old 05-16-2011, 04:59 PM
boldingm's Avatar
Default How to troubleshoot XYZ switch?
Is there any way to troubleshoot the XYZ switch (gear position switch). My 2000 LR Disco II is in the "limp" mode, M & S lights flashing. The "D" lights adjacent to the shifter are flashing and it stays in "D" and does not downshift when driving. I checked the battery and alternator. The battery is new, but I did remove the terminals and clean and retighten them. No help. I then checked the alternator which is putting out a solid 14 volts. I was told to see if the XYZ switch may be bad. I've removed it. It looks OK mechanically,,,nothing physically broken or damaged. So how can I check this thing out before I throw down big bucks for a new one that I might not need??
Matt B.
stu44mag
03-08-2023 11:45 AM
meltdowndave
11-05-2019 09:02 PM
meltdowndave
04-28-2019 09:53 AM
RicknCody
03-28-2010 07:49 PM
meltdowndave
09-26-2009 11:18 AM
Quick Reply: How to troubleshoot XYZ switch?
