Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-28-2011, 06:49 AM
Junior Member
Default no movement
had my 1996 dicovery 3.9 v8i auto serviced, day after car stopped, engine running fine, gears sound like there engaging, just no movement..anyone any ideas?
Old 09-28-2011, 07:48 AM
Send a message via Skype™ to Disco Mike
SO!!! what have you checked so far???
My money is on a failed diff, have you tried putting the t/case in High Lock, will it move then, if so, don't drive it, have it towed to your favorite mechanic for an inspection for a diff or failed CV joint.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 09-28-2011, 08:17 AM
Junior Member
had disco serviced day before it came to a halt..tried just about everything n it just wont budge. someone suggested it may be transmission fluid or filter..fluid looks fine, i havnt a clue how to get to filter (new to this, my first disco, and only had it for a few weeks) only other thing is it groans a little when putting it in drive.. never had any problems before it was serviced
Old 09-28-2011, 09:09 AM
So, have you tried what I suggested??????????????????????????????????
__________________
Mike
Need Parts?
Old 09-28-2011, 10:58 AM
Senior Member
Mike is trying to save what little money you have left after the service department vacuumed your wallet. That little short stick shift at the front of the console - it has a shift pattern like an "H". Put main transmission in "N", and wiggle the short shifter around and push it into the lower right corner of the "H", which is High range, unlocked. That is normal place for driving on dry pavement.
If the transfer shifter is in the middle - no power is sent to any wheel.
It is very easy for some one to knock this out of "gear" or not put it in gear firmly, if they were playing with it (service departments NEVER toy with customer vehicles).
__________________
Old 09-29-2011, 09:01 AM
Senior Member
Probably didn't install the filter correctly and its probably in the bottom of the pan not sucking up anything.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 09-29-2011, 11:54 AM
Senior Member
Exactly what services were performed?
__________________
Tags
movement, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
