Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-09-2011, 04:10 AM
Junior Member
Default oil leak
I have just purchased a 1995 land rover discovery v8i and have found an oil leak coming from above the oil filter i found one from the oil pressure switch so i replaced that then found another one from what appears to be a welsh plug just above the oil filter is it actually a welsh plug if not whats required to repair it well i think its a welsh plug its round and its set in from its sourround a bit
Last edited by Banning; 09-09-2011 at 04:14 AM. Reason: not enough infomation given
Old 09-09-2011, 04:51 AM
Senior Member
see post Oil pump/timing chain overhaul/ aftermarket gauge instal for pix of what is involved around the front cover seal, also download the free RAVE set of tech manuals if you don't have them, see below for link.
__________________
Old 09-09-2011, 05:45 AM
Junior Member
Default front cover spring
it would appear that the leak is coming from the bung where the oil pump spring is any ideas how to repair and that for that advice and link much appriechated
Old 09-09-2011, 06:57 AM
Senior Member
The RAVE manual should have clear drawings and write up on it. Note that other members have posted that they had success on small leaks with the White Shepard Oil Leak product where gaskets are involved. Many Rover things are sealed with hylomar (spelling?) similar to RTV.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
