Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-26-2011, 05:06 PM
Junior Member
chaz614
Question Oil Pan Gasket.
Hello All,
I recently Purchased a USED 1999 R.R. 4.0. I discovered it has an oil leak which appears to be coming from the front of the oil pan area. I'm no Mechanic by any means, but assume its just a bad gasket?? I have replaced gaskets before, is this as easy on a RR? Meaning: Darin Oil, drop pan replace gasket, mount pan back, fill engine with oil, and done?...
Old 09-26-2011, 09:18 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Yup, pretty much that simple.
Here is a tip, support the truck by its frame and let the front axle hang down as far as it can.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 09-26-2011, 09:23 PM
Senior Member
And be sure to clean around and inspect the front crankshaft seal, which is just in front of that oil pan, and can throw oil for some distance when leaking. Both my front seal and pan gasket are on the to-do list.
__________________
Tags
dicovery, discovery, forum, gasket, gaskey, land, oil, pan, rover, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
