Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-09-2011, 01:50 PM
Junior Member
Default P0102 code....
First time post....so apologize if this topic has been attended to in the past. i have 2002 discovery 2 ,Service engine soon light came on with autozone code read to be P0102. everything i read was MAF...i do offroad and noticed my engine cut off recently when i hit decent water hole, but wasnt deep enough imo to cut off, found it strange... i took air filter out and noticed trash in the bottom of the filter box due to some idiot that changed air filter last did not latch correctly and bent flap leaving a filter box open...also looked like a mouse ate a small hole in filter so i was getting trash, dirt, water etc past the filter. I pulled the MAF and cleaned with crc maf cleaner..changed filter and refit filter box. Service engine soon light is still on, its been one day. Anythoughts? thank you in advance
Old 09-09-2011, 10:08 PM
Senior Member
put a maf sensor that is OEM before it completely shuts down in a bad way. Seen a few do that and it leaves the person stranded.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 09-12-2011, 02:12 PM
Junior Member
OEM? original part...Bosch?
maf didnt seem bad visually, is there a way i can reset it, or maybe be something else?
Tags
0102, code, discovery, land, landrover, message, p0102, po102, range, rover, rvoer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
