Sponsored by: DashLynx
Please help... major.
Old 05-26-2006, 07:11 PM
CJsRover137's Avatar
Default Please help... major.
Sometimes there is a ticking at my feet and when I press the brakes it is firm and slips (the pedal doesn't go down, it shudders when i push but it won't go down unless i slam). Sometimes the steering gets stuck and shakes violently(shimmy or wobbles), or it will feel hard to control at higher speeds and veer side to side. Also, there is a loud grinding noise/crackled humm (the faster, the louder) that one wheel is worn, but the noise has really changed -->there is fluid on that wheel after parked for a while (NOT BRAKE FLUID). Any help or advice would be much appreciated.
Old 05-26-2006, 08:26 PM
05LandRover's Avatar
Default RE: Please help... major.
ORIGINAL: CJsRover137
check rotor is all i can say
Old 05-26-2006, 09:28 PM
You have an ABS/brake problem, a serious one.
It is safe to say one of your calipers are leaking and should be check ASAP.
I would think your brake fluid level is dropping, might out to check it, and don't drive the truck until you find the problem.
Start with the wheel with the fluid on it.
Mike
Old 06-08-2006, 08:32 PM
btp226's Avatar
Almost sounds to me like this could be a leaking seal around the swivel housing if it's not brake fluid. That would be the ticking you are hearing (the semi-dry CV joint going bad). and the leaking oil on your brake rotor would make your ABS act funny.
Did you ever get this resolved?
Brian
TATZOO
05-14-2012 10:14 AM
jbremser
12-26-2008 03:07 PM
direwolf41
Freelander
01-15-2007 11:17 PM
neutheory
Defender
10-09-2006 10:55 AM
Quick Reply: Please help... major.
