Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 01-06-2012, 03:37 AM
Junior Member
Default problem???
I was driving in fields today and when i got back on the road i heard a loud bang and then if i take out a gear whilst moving the whole landy starts to vibrate roughly and when i steer it feels like it s going everywhere. could it be a center bolt on the front axle or is it probably a more serious problem???
Thanks,
Daniel
Old 01-06-2012, 05:27 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Could be almost anything, you are going to have to look and see what it broken.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-07-2012, 01:13 AM
Junior Member
I jacked it up this morning and everything (suspention related seems to be fine), i tightened up the steering box adjuster cause i had some play in the wheel and reduced one of the shims on the diff wheels(the ones on top that are only on the front diff). I noticed that when I steer almost fully to the right the left side steering arm touches the spring is that normal?? i also found out that the landy was stuck on 4x4 so could the banging have been the transfer box???
the diffs seem fine no slack and bearings seem to turn free without too much friction
Also one of the previous owners messed with the springs as i have 12 on the drivers side and 11 on the passenger side (where the steering arm touches) but still it is slightly lower on the drivers side could it be chassis misalignment???
Any tips would be useful as this is my first land rover and it s driving me crazy lol
Old 01-07-2012, 01:38 AM
Member
The Land rover is permanent 4x4 vehicle so no doubt it is stuck in 4x4
if by any chance you had CDL engaged on mind anything could happen when driven with CDL ON on solid surface
question- did u lock the diff and forgot to unlock it?
how did you found out its "stuck in 4x4"
Old 01-07-2012, 02:30 AM
Junior Member
no mine is a series 2 so it has the old 4 speed box with 3 levers one for the gears (black knob) one to engage 4x4 (yellow/white knob) and the other to switch between high and low (red knob) at least according to the manual that s their job.
No the diffs don t lock on mine ( or i don t know how)
I noticed this cause when i jacked it and tried to turn the front wheels they wouldn t turn but when i jacked it to grease it last month they did. I then fiddled with the gear knobs and tapped on the transfer box and it got unstuck.
from some research i did transfer boxes like mine don t have differentials so they are not to be used on the road........ if that s correct could it be that that is the problem and all i have to do is not use 4x4 ??
Old 01-07-2012, 07:42 AM
Send a message via Skype™ to Disco Mike
You are a hard on to follow. What year is your truck, do you have CDL, was it engaged when you were playing? What do you mean you have 3 shift sticks, a D2 only has 2, the tranny and the T/case, do you not have a factory T/Case?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-07-2012, 11:27 AM
leadfoot's Avatar
Senior Member
This is hilarious, you have a series 2, with leaf springs and part time 4x4, while we all expected you to be talking of a Disco or something similar.
More than likely, you broke a shaft or axle, since you took it out of 4x4 and still could drive, it means you broke one in the front. Almost always is the long one. To make sure, lift the front end and turn one tire, the other should turn in the opposite direction. If it doesn't, you broke a shaft. And, no your car does not have a locking diffs. If you take it out of 4x4, and it does not drive, then you broke a rear axle. I am sure you know that once you engage the front diff by pushing down the yellow lever, you must engage the red lever in 4 low to disengage the yellow one. Kind of a pain. I grew up in Costa Rica and my grandpa had many of those Land Rovers. I know them well.
__________________
Land Rover Discovery 1997 152K
Mitsubishi Montero 1998 140K
Toyota FJ Cruiser 2007 50K
BMW Z3
Old 01-07-2012, 07:16 PM
Junior Member
lead foot it is a series 2 land rover with leaf springs lol the front shafts are fine although if i turn the right wheel the left one will turn in the opposite direction but if i turn the left wheel the right doesn t turn
what i found that s bad so far is the front axle has no oil not in the diff section nor in the parts where it steers so monday morning i ll go buy some oil
Old 01-07-2012, 07:49 PM
Senior Member
__________________
Old 01-07-2012, 08:13 PM
Philip Lawrence
This is why it is so important to tell us what year and model you have.
__________________
www.marshill.org
www.20liters.org
Tags
axle, happen, land, lockers, mitsubishi, montero, rover, spin, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
