If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Maybe change oil / filter again in a short period. Would hope that most of this has been trapped by the filter. But even a good Mobile 1 filter, with a 10 micron rating, can pass very fine silt (which goes down to about 4 microns). So while the sand and bigger stuff will be trapped in the filter, some small crap may still be in there. Bigger issue is new filter getting plugged up with the mud it traps. The oil also goes through the oil cooler on radiator before it gets to filter, if you can have a couple of o-rings on hand, you could clean that out as well.
