Sponsored by: DashLynx
DISCO TDI MANUAL GBOX FILLER
Old 06-04-2005, 09:59 AM
mmh's Avatar
mmh
mmh is offline
Default DISCO TDI MANUAL GBOX FILLER
Can anyone help before I go mad please.
Where is the filler for the Gearbox Oil on a Manual 1997 Tdi Discovery ?
Cheers in anticipation !
Marc
Old 12-25-2005, 10:24 AM
irishrover110's Avatar
Default RE: DISCO TDI MANUAL GBOX FILLER
It is on the right side about 1/2 way up the gear box. You will need to get right under the LR, and you may need a light. It is a plug type and it is also the level hole. It is not easy to put oil into. I use a siphon.It loots like a grease gun but it has a rubber tube on it.
Good luck
Dennis.
dirkha
02-10-2021 06:44 AM
Hercu
11-18-2012 08:12 AM
terryjm1
10-10-2011 05:39 PM
disco-112
02-12-2011 11:31 AM
apparition
08-22-2007 04:17 PM
Quick Reply: DISCO TDI MANUAL GBOX FILLER
