Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 12-22-2011, 06:35 PM
Junior Member
Default Steering Knock
I have a 94 v8i discovery and its making a knocking noise but only when I turn i can also feel it in the steering wheel while turning and looking out the window as I turn the wheels move side to side a little does any one have any idea what the causes might be and how I might be able to repair it. Thanks
Old 12-22-2011, 06:57 PM
Senior Member
Jack up wheels and wiggle top to bottom, and left to right. Movement indicates bearings problems. If you can feel it and notice it visually, you are close to failure, would be a good idea to drive something else. # 11 and #13 in attached drawing. Could also involve the swivel (CV ) joints, but they normally make a "popping" sound as part of the problem, even when straight.
__________________
Old 12-23-2011, 02:02 AM
Junior Member
Thanks for that I think that was quite helpful I jacked up the wheels and there was no movement so Im guessing that leaves the cv joints unless theres something else in there that can cause that kind of knock.
Old 12-23-2011, 05:16 AM
Senior Member
Check your front suspension bolts and tighten.
The panhard rod goes from the frame to the front axle ( 2 bolts)
And radius arms (2) cradle the front axle (4bolts). Sometimes you can see rust around the loosely bolted area.
Check your track rod and drag link ball joints for play.
Grab the front sway bar a wiggle it (up down and side to side), you'll know if the bushings are worn.
Once you have the wheels turned left or right you will notice there is more
backlash in the stering box therefore when wiggling the steering wheel in the
turned position (left or right) you will feel more play in the steering wheel.
__________________
Mike G
It's never over with a Rover...
06 LR3 W/G4 Accessory Package 94,000mi
04 Disco 2 128,000mi For Sale
99 P38 Bosch 70,000mi
66 GTO Convertible 427 Chevy
08 Buell 1125R
01 Kawi Concours
Old 12-23-2011, 08:36 AM
Send a message via Skype™ to Disco Mike
Also check your ball joints, especially the lower ones.
Let us know what you find.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 12-23-2011, 07:31 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Loose/broken shock mounts can knock too.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Tags
discovery, drag, f250, knock, knocking, knocks, land, link, noise, pop, rover, steering, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
