If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Happens about once every two months. My trunk door gets stuck, cant open it from inside or outside. I'm lazy, and just try to pull at it every so often, and sure enough, once in awhile it unsnaps and lets me open the door normally.
I sprayed WD-40 around the hinge, etc, but this keeps happening.
What to do? I cant afford to ask a mechanic to take the door apart
Download the RAVE service manual set, go to pdf file "LT" (in lower case), in there you will find wmlt016n.pdf , which covers D2s 1999 on, it is the workshop manual. Go to section "doors", under that "repairs", which has several including: "Door - tail", "latch and motor tail door" , and "handle exterior tail door".
Everything you need to know about it, easy DIY.
"You don't need a parachute to skydive. You need a parachute to skydive twice."
its the child lock on the mechanism causing the issue. its a pain but replace the latch not the handle and you will be fine. Its not fun to get into it when it does it but a right angle pick will get in and push it up.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
