Sponsored by: DashLynx
What does 'bad cylinder' mean?
Old 04-08-2007, 07:48 PM
bobby82569's Avatar
Default What does 'bad cylinder' mean?
I was told I have a cylinder that went bad on my 2000 4.6 Any info and about how much to replace? I have 94,000 miles on the truck. Thanks
Old 04-08-2007, 08:09 PM
fire1427's Avatar
Default RE: What does 'bad cylinder' mean?
Bad cylinder is pretty vague ... bad compression??? loss of power??? erratic ??? vibrations ???what were the symptoms ???
Old 04-08-2007, 09:19 PM
First, unless you switched out your engine, you have a 4.0.
How mentioned to you that you have a bad cylinder, is your truck running bad, have you let it over heat, are you loosing coolant or is your check engine light on?
Mike
Old 04-11-2007, 02:53 PM
bobby82569's Avatar
It's definetly a 4.6 maybe I wrote 4.0 in an earlier posting,sorry. I'm not sure what he meant by bad cylinder but I trust him since I'm friends with his daughter so I guess I'll find out more tommarrow . THANKS! Bobby
Old 04-11-2007, 02:59 PM
Bobby,
I am confused, did you change out your engine, if not, it really is a 4.0.
What is it doing to lead you to think it has a bad cylinder?
Mike
Old 04-11-2007, 03:17 PM
bobby82569's Avatar
It has been losing coolant
Old 04-11-2007, 03:21 PM
bobby82569's Avatar
The badge on the back tailgate says 4.6 HSE. It's a 2000 Range Rover.
Old 04-11-2007, 06:24 PM
[quote]ORIGINAL: bobby82569
I misunderstood, I thought it was a Disco.
Has anyone done a compression or chemical test on the coolant system?
It is most likely a leaking head gasket which is very common in Rovers so make sure they check before they start tearing into the engine.
Mike
Old 04-12-2007, 05:09 PM
bobby82569's Avatar
I don't think they have but now I'll tell them to do that first, thanks!! I'm glad you thought I had a Disco, had me thinking I lost my mind, again!! LOL
exjeep owner
06-01-2012 08:41 AM
DV57
03-02-2012 06:03 PM
Corrado
07-26-2007 05:00 PM
deuteronpsi
05-01-2007 11:13 AM
4x4freak
04-10-2007 12:48 PM
Quick Reply: What does 'bad cylinder' mean?
