Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 09-06-2011, 06:44 PM
Senior Member
Default When to replace ignition wires
How do you determine when you change out the ignition wires?
Obviously one that is causing a misfire, or is damaged, cut, broken, burned, arcing, etc. calls for replacement, but if they all look good, what other criteria do you use?
I checked resistance on mine and got from 1450 to 2100 Ohms depending on the length, shortest to longest. Most of them are right around 1800 Ohms. The resistance seems low, but high would indicate bad.
These wires are from STI, which I read are resistorized wires. I think this could be what Rovers North sells under the Proline brand but I'm not sure (I didn't buy them).
Old 09-06-2011, 08:46 PM
Philip Lawrence
Send a message via Skype™ to Spike555
This is what I do, change spark plugs every 30k and plugs and wires every 60k.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 09-07-2011, 05:31 PM
Member
+1 what spike said.
__________________
2004 Disco II SE
Black on Black
85,000 miles and counting
Tags
change, forums, ignition, land, plug, replace, rover, spark, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
