Stalling and kicking at speed
So out of nowhere a few weeks ago I was in somewhat slow traffic and I experienced a huge kick in the engine followed by another. Since then the kicks and momentary drops in power have continued on and even started stalling at the idle. I have a good collection of codes but don't know what to go after. I also cleaned my throttle body and took the idle control valve off and gave it a shot of carb cleaner as well as a light shaking. Codes are as follows:
P1884
P1590
P0441
P0455
P0133
P0430
P0153
P01412
P01415
P0102
P1174
im living with a very low budget so I really just want to know the most likely culprit since these codes seem to come from all over the truck
HELP!!!
P1884
P1590
P0441
P0455
P0133
P0430
P0153
P01412
P01415
P0102
P1174
HELP!!!
Doesn't point to anything with misfires which usually starts this symptom that you experienced. I may be off, but checking your charging system thoroughly is a good start. Battery post clamps and corrosion; tight and clean. Get the alternator tested, it's easy to remove. Just a lot of random codes that aren't closely related. Could be that ECU is not getting enough power
benisraeli
04-14-2012 01:15 PM
