Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Register Forgot Password?
Old 10-07-2011, 02:24 AM
Junior Member
Default Wiring Diagram on Hella Trailer 7 pin connector
Does anyone out there have the diagram of the trailer wiring on 2001 RR 4.6HSE (US version) that has Hella european 7 pin connector?
The color of the wires are Brown, Black, Green, White, Red, Blue and Yellow (all are solid color no stripe color combination).
I need to know which wire does what.
I'm trying to hook the trailer wire converter (Hoppy Brand) that has 5 wires at one end (GREEN-Right Turn; YELLOW-Left Turn; BROWN-Tail/Park; RED-Brake; WHITE-Ground) and 4-flat connector at the other end (to hook on Uhaul trailer).
How can I splice 7-wires into 5-wires and make all the trailer lights works properly without giving any "wierd" warning on the dashboard?
Search everywhere, can't find same wiring color diagram in the forum
Any help would be greatly appreciate it. Thank you!
__________________
Jet Black '01 4.6 HSE - "MR ROV3R"
140K+ miles and going strong....*x-finger*
Old 10-07-2011, 07:09 AM
Senior Member
Perhaps this will help. Not sure if exact year. You may be forced to use a volt meter to measure each wire to ground.
Pin numbers are on drawings, with wire color code.
Wire colors on drawings are:
 B - black
G - green
K - pink
L - "light"
N - brown
O - orange
P - purple
R - red
S - gray (slate)
U - blue
W - white
Y - yellow
__________________
Old 10-07-2011, 11:41 AM
Junior Member
Thank you!
The wire color chart and the PDF file are AWESOME!
...so I suppose the pin#4 on the C336 diagram is the bottom one in the socket right? (the one that has a "bump" on the socket)
Thank you again
__________________
Old 10-07-2011, 02:45 PM
Senior Member
These come from the RAVE, your own copy awaits below. Download, and take out the versions for other Rovers you don't currently own.
__________________
Tags
adaptor, anhnger, brown, diagram, european, green, hella, land, pin, rover, socket, trailer, white, wiring, yellow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
