If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
My 1996 discovery won't crank sometimes,motor turns over fine but not fireing.Wondering abought alarm sys.any way to check it and see if that is the problem.Had a Jeep once if the battery went dead I had to ret it in order for it to crank.Any help will be much app. THanks
Another won't crank but turns over, when will it end.
If the engine is cranking, then it is turning over. If it is turning over and won't start that is most likely either the fuel pump, fuel filter or crank sensor.
What have you checked so far?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
