'08 LR2 130k pause and jolt from 2nd to 3rd
My LR2 2008 SE with 130k drives fine for 10-15 miles. Then it has issues when shifting from 2nd-3rd (its an automatic). When accelerating, there is a pause, a knock noise and then a violent lurch/jump. The lurch only happens between 2nd > 3rd. The local mechanic hooked it up to the computer and says the diagnostic machine doesn't note any issues. Should I pay someone to tear apart the gear box / Transmission? Thanks in advance.
I have the same issue with my 2008 LR2 SE 98k miles/157k km. Going from 2nd to 3rd seems to hang on neutral for a moment and depending on speed and acceleration, it will rev up, jolt or knock. It only seems to happen when it's really hot outside (above 38°C/100°F, according to the outside temperature reading). During those same circumstances, it does the same thing when shifting from Drive to Reverse.
