2009 lr2 hse - Land Rover Forums - Land Rover Enthusiast Forum
Old 01-04-2017, 05:50 AM
Junior Member
Default 2009 lr2 hse
Climate Control issues: Cabin is over heating, defrost stays on while my feet are cold? Switching from Auto to Economy has no effect on interior temperature. Temperature dial will not modulate temperature. Heated seats are working fine. Directing air flow (defrost, dash or feet) has no effect. Replace climate control module?? Temperature sensor??
Thanks Bob
Old 01-04-2017, 07:50 AM
Junior Member
Another possible suspect is the Motor Lever Heater Flap (LR048448 or LR003173) modulates a door in the mixing plenum that is a possible bad actor.............anyway to test the motor?
Thanks Bob
Old 01-06-2017, 04:21 PM
Junior Member
I was able access the area (very tight) for the Motor Lever Flap (passenger side / behind the glove compartment) and the electrical connection is small, almost a micro connection. Trying to use a meter to test for voltage and continuity would be difficult. I have noticed that the control panel is easier to find / purchase used or new which makes me wonder if the control panel has a higher failure rate than the motor. Looking for some feedback from any tech's out there.
Thanks Bob
Thread Thread Starter Forum Replies Last Post
How long will a 2009 LR2 last? bkuberek LR2 10 10-05-2016 05:54 PM
[Another] Starting Issue - 2009 LR2 FAST5 LR2 1 06-27-2014 05:05 AM
2009 LR2 Custom infotainment Bastian Kuberek Modifications 0 04-18-2014 04:30 PM
2009 lr2 a/c windermereLR2 New Member Introduction 0 07-18-2013 05:39 AM
2009 LR2 Reduced Engine Performance warning JakeHalliday General Tech Help 2 02-23-2011 10:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
