Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR2
Register Forgot Password?
Old 08-31-2007, 10:10 PM
Member
Default DiscoMike-where are you?..
I have LR2 w/o Nav/bluetooth since May w/ no issues except for no sound/amp. not loading (fixed by software reload), and minor rattle in both front door panels ( I think).
I was debating if I should install bluetooth into my LR and which one -Parrot 3100 ($300by the local reputable shop), or OEM Bluetooth kit (about $600 parts only).
from my experience w/ Volvo dealer they did not like ANYTHING aftermarket, and tried to blame window problem on my aftermarket tweeters...
So I am ready to get OEM kit, but have a couple of questions I hope someone on this forum can answer:
1. Do electric LR parts come with installation instructions?
2. Is the kit a "plug-and-play" thing, or I will need to go to thedealer to get a software/ re-set done?
Thanks a lot for your help.
PS
Question #3: is it a diy job?
__________________
2008 LR2
2010 Q5
Old 08-31-2007, 10:49 PM
Senior Member
Default RE: DiscoMike-where are you?..
The Land Kit istough to install (4-5 hours) because it is a plug in kit it does not compromise your wiring or warranty,DIY is not for this kit ! it also requires vehicle reprograming. everything does on the new cars with CAN BUS wiring,
Beware when wiring aftermarket accessories, never cut or tap into any wiring that is twisted, these are CAN BUS circuits and they are wires using digital signals, you cant shorten them or tap into them , you'll cause hours of stress for some poor tech.
__________________
current gold certified LR master Technician,ASE master cert,ASE L1 cert,With LR dealers since 1987,91 GDE classic,2 disco 5 speeds,a 95LWB. my current classic a 95 LWB 25th anniv addition with (148k)and another 94 disco(135k)
Old 09-05-2007, 01:44 PM
Member
Send a message via Yahoo to VermontRoverGal
Gotta agree with Dirtyduk. I looked into the Bluetooth aftermarket items before we purchased our LR2. None are without their own problems. When I ordered my LR2 last October, we added the Bluetooth to it because of all the negative comments from the LR techs about people installing their own "kits" after purchase in other LRs. Out of curiousity, is it a $$$ thing that is making you look to aftermarket, rather than to the LR2's own Bluetooth kit? If so, I think you may end up spending lots of dollars more in the end with an aftermarket kit, just because of what Dirtyduk has posted.
__________________
VermontRoverGal-they can have my Land Rover when they pry it out of my cold, dead fingers!
Old 10-22-2007, 11:41 PM
Member
Quote:
ORIGINAL: dirtyduk
I read on another forum that OEM i-pod kit did not require any software downloads, and was not that difficult to install-do you know for sure that BT kit needs software and is 4-5 hours to install?
I am considering LR kit because it will not void the warranty, and will not add any "new" display to the dash...
Thanks a lot.
__________________
2008 LR2
2010 Q5
Tags
2010, aftermarket, application, bluetooth, discomike, kit, land, lr2, parrot, rover, tweeters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
