front passanger door lock malfunction
Old 03-12-2014, 07:27 AM
jackmanmachine's Avatar
Default front passanger door lock malfunction
without warning my front seat pass door lock wont unlock with the others. when I try to pull it up manually it yanks back down. any guidence to this end?
Old 03-12-2014, 11:46 PM
LR2driver's Avatar
I have a similar problem, but with the drivers door. I posted about it a couple days ago.
I found a post on another forum describing a similar problem, but no solution. Here is the post:
Freel2.com - View topic - How do you make the drivers door unlock all doors on exit?
I'm thinking of trying a "hard reset" that I've read about where you disconnect the battery wires, then touch the positive and negative wires together which drains all devices and resets them. Sounds like a strange process, so I'm just working up my nerve to try it.
CaptainCulp
09-08-2013 01:19 PM
Disco23
05-11-2008 07:49 PM
grrRover
12-17-2007 03:36 PM
rravenn13
06-29-2007 02:46 PM
sadystikal1
12-18-2006 07:56 PM
Quick Reply: front passanger door lock malfunction
