03-08-2009, 04:13 PM
Junior Member
Great Find -- Car Care - Brake Dust Repelent!
My LR2 has a real penchant for producing brake dust which darkens my wheels within 2-3 days after cleaning. I saw this new 2009 product mentioned on a blog the other day and decided to give it a try. Holy cow!--- it works better than I would have imagined. After almost 2 weeks including 2 major rainstorm, my wheels are clean -- well at least cleaner than they would have been normally. The stuff was a little hard to find (3 auto store visits) and while it dries clear, it does leave a slight residue if you look very closely. But man it works. Better than blackened wheels at least. Not sure how it would do on chrome wheels given the coating effect, but on aluminum cast, it is great.
Probably really toxic and poisoning the environment. But my wheels are clean! See below
_______________________________________________
Keep Clean Wheel™ – 18 oz. By Eagle One
Repels brake dust & road grime for up to 2 weeks
Apply after cleaning wheel (this is not a wheel cleaner)
Protects wheels from corrosive brake dust
Makes it easier to clean wheels every time you wash
Usage directions:
Make sure wheel is clean and completely dry of water before application
Shake well before using
Hold approximately 4 to 6 inches away from wheel surface.
Spray wheel surface with a THIN, EVEN coating of product. Be sure to cover recessed areas, so the entire surface is covered.
Do not touch the wheel once you have applied the product as this will remove the coating from the surface of the wheel.
IMPORTANT NOTE:
Surface should appear wet. During the drying process, the surface of the wheel will appear hazy for approximately 5- 15 minutes. Wait 10-15 minutes before using your vehicle. Coating will be invisible once it has dried
