Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR2
Register Forgot Password?
Old 06-19-2009, 09:01 AM
dwc dwc is offline
Junior Member
Default LR2 brake and steering noise and pedal response
I have a squeeking/streching sound from the front when brakes are applied, even slightly and move the steering wheel. I took it in to see in case it was something that may be going out, but they cleaned the brakes and said nothing was wrong. Brakes seem to work OK, but sound still remains.
Any one else have this issue?
Also when accelerating after slowing down, pedal response is very slow. Keep pushing down and not much happens, eventually it will kick in and go. Also they said that was not a problem. Is this also common?
Darren
Old 07-21-2009, 06:26 AM
Junior Member
Hi Darren,
I have this exact same problem. I live in a condo, and I notice that sound (like a squeak, stretch, crunch sound) when I round the corners and apply the brakes. I haven't taken it in, but it almost sounds like the suspension is creeking as I turn the corners. Sounds bad. My servicing will be coming up so I will mention it to them then.
Cheers
Jason
__________________
2008 Land Rover LR2 SE - Tambora Flame
Old 09-05-2009, 05:48 PM
Junior Member
I just had my LR2 in for servicing, and I reported this problem to the dealer. They test drove 2 other LR2's on the lot as well, and noticed that ALL of them have this problem. The isolated it to being the geometry of the suspension under breaking at low speeds and turning, and that the pressure pushes the struts/springs into a crunching position, but nothing to worry about. Apparently the suspension was designed for more of an up and down motion, rather than a "up/down forward" motion.
Hope this helps - at least it's nothing problematic - for now
Cheers!
jason
__________________
Tags
brake, brakes, codes, land, landrover, lr2, noise, noises, problem, rear, repair, rover, squeek, steering, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
