Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR2
Register Forgot Password?
Old 09-17-2010, 12:53 PM
Junior Member
Default lr2 fuse box connection
I would like to hard wair connect my radar detector and gps to the passengeer side fuse box in my 2008 lr2. I would like the connection to be controled by the ignition switch. Does anyone know where to make the connection?
Thx
Old 09-19-2010, 09:42 PM
Junior Member
Get a cigarette lighter extension or one that splits into 2 adaptors. You need to preserve the cigarette adaptor end on your accessories as they convert the 12V down to 5V or so. Cut off the end of that extension and hook it up to one of these:
http://www.google.com/products/catal...wAQ#ps-sellers
Make sure you get the smaller one as the fuses are the small versions. Land Rover uses a 15A fuse for the cigarette lighter, you would probably be fine with a 10 as each accessory probably only draws and amp or two. There are a couple extra slots in the fuse box, just make sure you find one that turns off with the key (use a multimeter to find them). Ground the cable with the bolt next to the box.
Kevin
__________________
2010 Biscay Blue LR2 with climate package.
Old 10-01-2010, 12:12 PM
Junior Member
Default Hard wire to fuse box
Thx Kevin, I followed your advise and am now in business. I could not find a switched connection to tap into in the passenger side fuse box. So I tapped into the fuse for the cigarette lighter under the hood. I ran the wire to the small cover (to check transmission fluid I think?). In that area in the firewall was a small rubber plug. I ran the wire through that hole and to the inside passenger side just behind the fuse box. The rest of the connections were done per you instructions. Thx Again.
Old 10-02-2010, 03:00 PM
Junior Member
Quote:
No problem. I'm using the fuse F5 to power my GPS and it turns it on and off. hardest part was finding a good ground connection.
__________________
Tags
09, 2008, 2010, box, connection, f5, fuse, fuses, ignition, land, lr2, lr4, making, rover, tap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
