LR2 hesitation when starting engine
Old 01-12-2015, 05:37 PM
Nate Sampson's Avatar
5th Gear
Default still resolved?
Has there been any starting issues since the spark plugs have been replaced?
Originally Posted by LR2driver
Update [SOLVED]: I had my 2008 LR2 into the dealer for the 75K mile routine service where they replaced the spark plugs (per maintenance schedule). Following this change, my LR2 starts up like when it was new! No hesitation anymore. So it must have been the plugs. I only wish I asked them to save the old plugs for me so I could visually check if they appeared fouled. I would have been better off changing the plugs at 50K miles, but I didn't realize that bad plugs are a common cause of starting problems. I should have thought of this as the battery and starter tested OK. Live and learn.
Old 01-12-2015, 05:44 PM
LR2driver's Avatar
Yes, a couple times when I attempted to start the engine, all the dashboard indicator lights would come on and the engine would not crank. After waiting a moment and trying again, it started.
After about 6 months, it would not start at all. There was no engine crank or other sounds. The battery was tested and had a full charge. The problem was a failed starter motor. So I had to flatbed the vehicle to the dealer to have them replace the starter. They didn't stock them, so I had to wait a day for them to get one.
This starter replacement is the only major repair I've had for this vehicle. Everything else has been maintenance and replacement of wear items. It's been starting fine since the starter was replaced a couple months ago.
Nate Sampson (01-12-2015)
Old 01-12-2015, 06:07 PM
5th Gear
My LR2 has had similar starting issues over the past year or so. Battery has always checked out fine, so I figured it's most likely the starter. I'll swap the plugs out first and see how it goes. Thanks for the update.
lazerbrains
LR2
38
08-09-2023 07:54 PM
Motorhead1
08-05-2015 05:11 PM
Tim P.
01-23-2013 03:16 PM
JerrodSteph
09-21-2008 11:52 AM
back179
Freelander
09-17-2007 09:07 AM
Quick Reply: LR2 hesitation when starting engine
