transmission fluid
This vehicle uses an Aisin (not pronounced Asian) transmission. You need to find ATF that is Type T-IV. This is a very common fluid for Toyota, but is found on any vehicle using Aisin, including Volvo (which is where the LR2 motor comes from) some Audis and some Porsches. We use Idemitsu fluid, but any brand that meeds Type T-IV will work.
See picture below: This is what the manual call for (the Toyota T-IV is fine also)
if you ae going to change the fluid you should take a look at the UK site Freel2.com - View topic - Auto Gearbox Oil Change TD4 MY07-12
LRScott
03-04-2009 08:39 AM
