water/pwr steer pump
Old 11-12-2016, 05:36 PM
fostera's Avatar
Default water/pwr steer pump
Can you describe to me the proper sequence to remove the power steering pump and put back on for a 2008 LR2. The specific question is the spring. I removed the power steering pump and it had the spring on it. There is a little white, coned shape piece that fell out. I didn't see which way it come out. It is thin and pointed on one end and round on the other. Also, do I mount the spring on the water pump first and then secure it to the pulley on the new power steering pump? You can reply to my email if you like: ab.foster@brentwoodtn.gov
Thanks,
A. B. Foster
Firefighter/Paramedic
Brentwood Fire & Rescue
fosteraView Public ProfileSend a private message to fosteraFind all posts by fosteraAdd fostera to Your Contacts
Quick Reply
Message
Originally Posted by fostera
Can you describe to me the proper sequence to remove the power steering pump and put back on for a 2008 LR2. The specific question is the spring. I removed the power steering pump and it had the spring on it. There is a little white, coned shape piece that fell out. I didn't see which way it come out. It is thin and pointed on one end and round on the other. Also, do I mount the spring on the water pump first and then secure it to the pulley on the new power steering pump? You can reply to my email if you like: <a href="mailto:ab.foster@brentwoodtn.gov">ab.foster@ brentwoodtn.gov</a> <br /><br /><br />Thanks,<br /><br /><br />A. B. Foster<br />Firefighter/Paramedic<br />Brentwood Fire &amp; Rescue
<br />
Agripper
10-21-2015 03:04 PM
screamin demon
11-12-2012 10:41 PM
kman3786
06-20-2012 11:06 AM
Jason_B
04-18-2010 05:11 PM
Quick Reply: water/pwr steer pump
