AC quit a week after recharge
Old 08-26-2012, 04:34 PM
Brianjw82's Avatar
Default AC quit a week after recharge
My AC on my 06 se v8 didn't feel cold enough so I had an Indy shop recharge my system. I've used them for years and they are familiar with rovers so I have no doubt the work was done correctly. My mechanic told me the refrigerant was low and had been recharged. Air was ice cold for about a week and today I got in and had warm air. The blowers are working fine and the rear ac blows warm as well. Any help is appreciated.
Old 08-26-2012, 06:29 PM
Back to the shop, you have a leak, and freon along with contents of wallet went out into space. They'll find the leak and re-do it. There was a leak to start with that cause the refrigerant to run away. Think about it, the same sort of material is hard at work 24/7 in your fridge, and how often have you recharged it? If refrigerant is gone, there is a leak. It does not "wear out".
Old 08-26-2012, 07:02 PM
Brianjw82's Avatar
The weird thing is that the Ac worked but it I didn't get cold until you were at highway speeds. Around the city it worked but not great. Once it was recharged it was freezing cold and now it's like a switch was turned off. Btw, the compressor is turning on.
Old 08-26-2012, 10:36 PM
bbyer's Avatar
Default Add dye to the refrigerant.
When I had my AC system recharged a couple of years ago, I had the dealer add UV dye to the mix. The idea is that it is then easier to find future leaks.
In my case, there was no specific leak, more just a first recharge in five years kind of thing but you know that at some time in the future, a leak will develop.
duckhunteryolo
06-23-2018 01:02 PM
demonlarry
08-07-2011 05:40 PM
Kanata.disco
05-31-2011 08:15 AM
robbster91
06-03-2010 09:58 PM
jrkstore43
06-16-2009 08:34 PM
Quick Reply: AC quit a week after recharge
