Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 01-04-2012, 02:12 AM
Junior Member
Default Amber Parking Brake Light
Just had the amber parking brake illuminate (constant) with a parking brake fault message in the information center.
2006 LR3 HSE with 35,800 miles.
Fluid is a little low due to the normal wearing of pads and the increased travel of the caliper piston, but still well above the minimum.
I am the same guy who has the DVD/NAV problem and will eventually take the LR3 in for that, but do I need to take it in immediately for the brake issue?
Should I check for any quick fixes beofre taking it to the dealer?
Thanks for the assist!
Ynot
Old 01-04-2012, 02:11 PM
Member
Is your D3 manual or auto
If its auto and handbrake is not making screeching sound most likely the switch
Old 01-04-2012, 08:17 PM
Senior Member
Send a message via AIM to unseenone Send a message via Skype™ to unseenone
I would agree with the switch prognosis. The only time I ever had that light (along with the usual Christmas tree) the switch was intermittent.
__________________
PM me for information on Differential rebuild Parts
Old 01-04-2012, 08:19 PM
Senior Member
umm no by a million years. its called diagnosis, not throwing parts at it. There are tons of bulletins for the codes that infect the system and yes you will need to get it diagnosed.
alot of the issues on that system is wiring related.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-05-2012, 01:11 AM
Member
well..... here in UK not a single D3 i worked on had a wiring problem
vast majority of faults are lack of adjustment and "coffe over the switch" issue
wondering if all wiring issues are reserved for US market - maybe???
if so im sorry for sharing my experience (based on European spec)
And yes im using SDD/IDS system on a daily basis and yes again im reading
TSB's using them as guidelines
but when asked for help my answers are based on my own experience
Old 01-05-2012, 03:56 PM
Senior Member
My apologies for the impression. Every problem is different. To put a little humor on the subject. Nobody wants to take the fun out of a little help forum.
__________________
Tags
2006, amber, brake, break, continuous, fault, land, light, lr3, orange, park, parking, range, red, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
